My browser returns a connection error (Took to long too respond)
beatforums.com took to long too respond
It has been happening on and off for a couple of days
opens instantly for me
Yeah it worked for about 30-40 minutes. It stopped working again now…
Until you have an SSL certificate installed and configured on your web server, your website will only support HTTP connections. If you want HTTPS connections, you gotta get an SSL certificate. Browsers do not automatically upgrade HTTP connections to HTTPS without the website being properly configured with HTTPS using an SSL certificate. I think Brave browser upgrades HTTP to HTTPS automatically, but the issue you’re most likely experiencing is you trying to use an HTTPS link without an SSL certificate. Hope that helped.
And look at this How to force all traffic to HTTPS
I just ran a check on your nameservers and it appears that currently the only countrys that are resolving them are malaysia and mexico ?
have you been changing name servers recently ? if so it can take up to 72 hours for things to settle into place
I have not changed the nameservers recently. That sounds pretty odd.
I used this website to check, its usually but not always accurate
when I check my site with it it shows every county ok except mexico, germany and south korea
Your website is also on the IP address 185.27.134.33, which has seen some downtime yesterday and earlier today.
