This is to inform you that After the installation of word press my admin word press of cPanel link is not opening, some time my wordpress admin cPanel showing that you entered wrong I’d and password, can you please guide me and resolve my issue, you can check in you history since I am facing this issue from couple of days but after long tries I found this address for the resolution.
My cPanel of Wordpress is not logging in after the Wordpress installation.
For starters, please don’t hijack other people’s posts, even if they are about the same software.
Second, are you talking about our hosting control panel login or your WordPress admin login? You use both words in tandem while they are typically used to refer to different systems (with different credentials).
