My website is https://lmisdumingag.com. Registration submissions return 403 Forbidden from OpenResty.
Testing /register.php shows:
Normal URL-encoded POST: HTTP 200, with the expected PHP validation error.
Multipart POST containing only registration_role=student, with no files: HTTP 403.
Could you investigate why multipart requests are rejected and explain how to resolve it?
This looks like the same problem several other people reported today: multipart POSTs get a 403 from OpenResty, while URL-encoded POSTs work. Two of those topics are below.
Here’s one where a multipart request with a single text field and no file is blocked:
And one where multipart POSTs to any path on the site are blocked, and they worked until yesterday:
I couldn’t find a knowledge base article or staff answer that explains the cause or gives a fix. Your tests show the 403 comes from the web server in front of PHP, so nothing in your code or settings is likely to change it. I can’t help with this one, and a person needs to have a look.
