Move upload file dosen't work? Pls help
I upload the Website and everything work perfect but when i try to upload image dosen’t work.
Image is been saved in database but not in the Uploads folder.
My code :
$user_img = $_FILES[‘register_user_img’][‘name’];
$upload_user_image_path = “/Uploads/users/” . $_FILES[‘register_user_img’][‘name’];
move_uploaded_file($_FILES[‘register_user_img’][‘tmp_name’], $upload_user_image_path);
Try this:-
PHP
<?php
$target_dir = "/Uploads/users/";
$target_file = $target_dir . basename($_FILES["register_user_img"]["name"]);
$uploadOk = 1;
$imageFileType = strtolower(pathinfo($target_file,PATHINFO_EXTENSION));
// Check if image file is a actual image or fake image
if(isset($_POST["submit"])) {
  $check = getimagesize($_FILES["register_user_img"]["tmp_name"]);
  if($check !== false) {
    echo "File is an image - " . $check["mime"] . ".";
    $uploadOk = 1;
  } else {
    echo "File is not an image.";
    $uploadOk = 0;
  if($uploadOk == 1){
     if (move_uploaded_file($_FILES["register_user_img"]["tmp_name"], $target_file)) {
     echo "The file ". htmlspecialchars( basename( $_FILES["fileToUpload"]["name"])). " has been uploaded.";
  } else {
    echo "Sorry, there was an error uploading your file.";
HTML
<!DOCTYPE html>
<html>
<body>
<form action="upload.php" method="post" enctype="multipart/form-data">
  Select image to upload:
  <input type="file" name="register_user_img" id="register_user_img">
  <input type="submit" value="Upload Image" name="submit">
</form>
</body>
</html>
Tnx for reply. I try this and result is the same. Image URL is saved in database but Uploads folder is empty. I don’t know where the problem is.
Can you tell me which output is throwing by this code?
File is an image - image/jpeg.Sorry, there was an error uploading your file.
Try:-
Replacing this line to
This
$target_dir = __DIR__."/Uploads/users/";
Working finally.
Solution : Missing dot - “./Uploads/users/” .
Happy Coding :grinning:.
