I just tried installing Moodle on a test account and I only get that third error.
As for the first and second errors, please note that an out-of-the-box Moodle installation requires 38,000 inodes, while the maximum for an entire hosting account is 60,000. So if you host Moodle, you’ll basically need a dedicated account for it, because it’s so big you can’t really fit any other sides alongside it.
The account to which that domain is linked has a number of other domains and websites, with not enough inode space being left for a Moodle installation.
As for the first error, I’m unable to find what exactly is causing it. All I know for sure is that it’s an error generated entirely by Softaculous, as the Moodle developers seem to have no idea what it is about.
So you can try to do a manual installation instead.
Moodle was successfully installed, but it gives me this error:
Fatal error: $CFG->dataroot is not configured properly, directory does not exist or is not accessible! Exiting.
Ok, I managed to fix the problem, I will continue with the environment configuration. Thank you in advance for your help .
I lead an institution focused on developing mechanisms for easy access to data encryption. Check out our website if you are interested in being part of this project. https://ebs-systems.epizy.com/
We are still a small organization, but we see great potential in this work
