Missing SSL Intermediate Certificate Chain
https://tejodhar.in/
Subject: Missing SSL Intermediate Certificate Chain — tejodhar.in
Hello InfinityFree Support,
My domain “tejodhar.in” has an active Google Trust Services SSL certificate, but an SSL checker reports:
“Server did not send a required intermediate CA; the chain completed only because the checker fetched it via the issuer’s AIA URL.”
Termux “curl” reports “unable to get local issuer certificate (20)”, while Google verifies successfully from the same device.
Please check the SSL certificate chain served by the hosting server and configure the required intermediate certificates.
Thank you.
Wait for their response before changing or reinstalling certificates.
This is expected on free hosting, and there’s nothing for anyone to fix on the server. The certificate chain is served without the intermediate certificate, and installing intermediates isn’t supported on free accounts. It’s only available on premium hosting. Your certificate itself is fine.
Browsers fetch the missing intermediate on their own, which is why Google and normal visitors verify the site without trouble. SSL checkers and programmatic clients like curl in Termux are stricter, so they report “unable to get local issuer certificate”. Our article on this says it only affects testing tools and programmatic access, not your visitors:
If you need curl to work without errors, you’d have to use premium hosting. Otherwise there’s nothing to change, so you can leave the certificate as it is.
