Hi my problem is that my backup file is 4 gb and to upload a file to migrate the website the maximum is 20 mb is just ridiculous. Any help to change that maximum? thanks I need help asap please
Im using all in one wp migration plugin in wordpress
Plugins do not work well on free hosting
This is the preferred way
Im trying to migrate from localhost to infinity free . I have the backup ready my problem is the max size to upload files in the all in one wp migration plugin ![]()
thanks anyway
You could just upload all of your site’s normal files (not the backup file) using Filezilla. Filezilla will upload one after the other, so the max limit for individual files won’t apply (unless at least one of your files is super big). Then just import the database, and change the URL in your WordPress configuration if needed.
Using WordPress backup plugins is not advised because they put a ton of unnecessary strain on the server. In fact, WordPress themselves doesn’t recommend them.
