Websites hosted on IP address 185.27.134.142 are unreachable
Affected: Website IPs · 2 other incidents
Ola.
AO acessar minha conta aqui no InfinityFree, vi que sumiu meu dominio e meu projeto. O estranho é que meu site esta no ar, mas nao acho meu projeto aqui no Infinity para edita-lo.
O que aconteceu? Perdi tudo? Nao posso perder..como faço para recuperá-lo?
Por favor, aonde estao meus arquivos, me ajudem!!!
Translation:
Wave.
AO access minha conta aqui no InfinityFree, I saw that my domain and my project were summed up. It’s strange that my site is not there, but I have my project here in Infinity to edit it.
Or what happened? Did I lose everything? I can’t lose it…how do I get it back?
Please, where are my files, help me!!!
Yes, my website is still online and running normally. However, my account dashboard is completely empty. There are no domains listed, and all my files have disappeared from the control panel.
Since my account is showing as zero, where can I find the FTP credentials (Host, Username, and Password) that I need? Where should I look in the panel?
Also, where are my files located if nothing shows up in my account? Please help me recover my access and my files
You can find the account by logging into the correct members area profile, which is not this one. I suspect that the other profile might be under a different email address that you own, so you may want to try a password reset using your domain name to get a clue as to which one it might be:
You were completely right! I found the correct account using that method. Thank you so much for your help and guidance with this. Everything is solved now.
