Mediawiki term infinityFree term match
http://sebul.sarang.net/w/mw-config/index.php
[ZaKqtIRqvujgSzmGP1r-1AAAABo] /w/mw-config/?page=Name Error: Failed opening required ‘/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/wikimedia/common-passwords/src/common.php’ (include_path=‘/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/console_getopt:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/mail:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/mail_mime:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/net_smtp:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/net_socket:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/net_url2:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/pear-core-minimal/src:/home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/pear/pear_exception:.:/usr/share/pear/’)
Backtrace:
from /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/wikimedia/common-passwords/src/CommonPasswords.php(14)
#0 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/vendor/wikimedia/common-passwords/src/CommonPasswords.php(24): Wikimedia\CommonPasswords\CommonPasswords::getData()
#1 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/password/PasswordPolicyChecks.php(159): Wikimedia\CommonPasswords\CommonPasswords::isCommon(string)
#2 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/password/UserPasswordPolicy.php(149): PasswordPolicyChecks::checkPasswordNotInCommonList(boolean, MediaWiki\User\User, string)
#3 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/password/UserPasswordPolicy.php(110): UserPasswordPolicy->checkPolicies(MediaWiki\User\User, string, array, array)
#4 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/installer/WebInstallerName.php(232): UserPasswordPolicy->checkUserPasswordForGroups(MediaWiki\User\User, string, array)
#5 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/installer/WebInstallerName.php(38): WebInstallerName->submit()
#6 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/includes/installer/WebInstaller.php(273): WebInstallerName->execute()
#7 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/mw-config/index.php(82): WebInstaller->execute(array)
#8 /home/vol13_2/freecluster.eu/fceu_18338360/sebul.sarang.net/htdocs/w/mw-config/index.php(40): wfInstallerMain()
#9 {main}
How can I match mediaWiki term and infinityfree term?
MediaWiki Term
Database host:
Database name
Database username:
Database password:
infinityfree Term
MYSQL USERNAME
MYSQL HOSTNAME
MYSQL PASSWORD
MYSQL DATABASE NAME
mediawiki vs infinityFree Following is OK or not? I don’t know.
Database host: MYSQL HOSTNAME
Database name: MYSQL DATABASE NAME
Database username: MYSQL USERNAME
Database password: MYSQL PASSWORD
Yes!!
Hi Sebuls,
MySQL is a type of database that IF uses, just fill in the host, database name, username, password and things will work. You current mapping is correct.
Cheers!
Just to be clear, the error message you’re seeing is because there appear to be critical files missing from your MediaWiki installation, it’s not a configuration or database issue.
To fix that, you can download a fresh copy of the MediaWiki code, and upload the missing files to your site. You can choose to either upload the missing files individually by looking at the error message (in this case, that’s sebul.sarang.net/htdocs/w/vendor/wikimedia/common-passwords/src/common.php), or just upload a complete fresh copy of MediaWiki over your existing site to add any missing files.
There are two caveats though:
  • Please make sure to download the exact same version of MediaWiki as you have installed. Mixing source code from different versions may not be compatible and lead to more issues.
  • Please watch the inode counter in the control panel. A single hosting account cannot host more than 30,000 files and directories, and an up-to-date MediaWiki installation is very close to that limit. The inode limit may be the reason the files went missing in the first place.
