MediaWiki not working
nicetools.gq/wiki/
Error contacting the Parsoid/RESTBase server (HTTP 500)
I get this error, when I click on “Edit” on my wiki.
Does MediaWiki work on InfinityFree’s free plan?
MediaWiki should work here.
Can you screenshot the error message for me?
Thanks!
Edit: I found this on their forums.
https://m.mediawiki.org/w/index.php?title=Topic:Vv23nm75ef2cyxtn&topic_showPostId=w3zq3i87keubvsn6#flow-post-w3zq3i87keubvsn6
And this as well:
Can you try installing an SSL certificate to see if it makes a difference?
I have used MediaWiki here previously, however it was quite slow. However, it should still work. As Greenreader9 said, can you please share a screenshot of the error?
Screenshot 2022-01-04 181918
See my edit above @anon32498208
I did already install SSL using Cloudflare.
Your right, I must have missed that, sorry.
I am able to recreate the error on my side, so perhaps a reinstallation might work? Unfortunately, I have never used the software myself, so maybe asking the question to mediaWiki support will get you a better answer.
I made a topic here: MediaWiki not working with InfinityFree on Project:Support desk
I made topic on the MediaWiki forum.
