Hi,
I get this error when I upload any pdf(200Kb) to my mediawiki site.
[W5TJYLvZUmgpvof7U4BBPwAAACE] 2018-09-09 07:18:57: Fatal exception of type “MediaWiki\ShellDisabledError”
Please assist me on this. Thanks!
Hi,
hi
please read the full text (of course you can not change some things because you do not have authority over the server)
but a part that talks about permission, file types, enabling upload ON, etc. certainly read
https://www.mediawiki.org/wiki/Manual:Configuring_file_uploads
if anyone wants to see php info (what is possible or not)
because it seems to me that it was removed from the control panel
create some php file and name it eg. info.php
put this code inside
<? phpinfo(); ?>
and visit that file over your browser
CTRL + F (search terms)
@irfantgv said:
Hi,I get this error when I upload any pdf(200Kb) to my mediawiki site.
Shell commands is disabled on free hosting.
@UnknownLolz That’s it and sad too
Because I never saw this error on my localhost. And thanks for the suggestions @OxyDac ![]()
Wish there is someway to resolve this ![]()
@irfantgv said:
@UnknownLolz That’s it and sad tooBecause I never saw this error on my localhost. And thanks for the suggestions @OxyDac
I feel sorry for you ?
I found this online though and maybe this can help you:
https://mediawiki.org/wiki/Topic:Qtyxrq15u3s0xm7y
Thanks @UnknownLolz
I referred that as well. The error seems to be from the mediawiki core which I am scared to make changes. Many other things like Syntax highlighting requires shell access to give executable permissions to the php scripts.
not so dangerous
go to the client area
manage> go to file manager
open with monstaFTP a folder of mediawiki (mw19) in htdocs
find a file named there LocalSettings.php
right mouse click on it and choose edit
find line $wgEnableUploads = false;
and change it to $wgEnableUploads = true;
then go down to the bottom and in new free line
paste this $wgFileExtensions = array( 'png', 'gif', 'jpg', 'jpeg', 'pdf');
than save and close
I have selected some extensions for you … and if you read the article I gave you
just add more.
then go to your mediawiki and on the LEFT you will have to upload (txt link)
if you are logged in as an admin
i have tried and uploaded pdf
Thanks for the tips @OxyDac , actually this is the current setup and works out of the box on my localhost. I tried re-editing the file as per above config. Still the same.
during the testing
make sure that you have deleted browser cache and cookies to see the new state
edit with monstaFTP because some editor added BOM, etc.
make sure that you do not have a plugin that creates a problem
I tested on clean installation
I made you a video https://drive.google.com/file/d/1f-uLnmrdgiMJSNvoug3S3WrnCuTW0bJb/view?usp=sharing
choose the highest quality
also check if your pdf extension is written in lower case
if is with capital letters example.PDF it is possible that it will be rejected
