Me aparece un diseño anterior y no el actual que puedo hacer?
Hello, and Welcome to the InfinityFree Forum!
Please note that this is an English-speaking forum, we only speak English around here. Please write your posts in English, it is okay to use a translator if necessary.
I have translated your question for you:
I see a previous design and not the current one. What can I do?
It sounds like you’re dealing with browser cache. Try hard-refreshing the page.
Also, please post your URL for us to help you out.
Ok thanks
my URL is
http://diagramaketa.kesug.com/
That shouldn’t come out but a new design, help please thank you.
I assume when you say “previous design” you mean that you reworked your webpage and can’t see the new version?
Have you tried clearing the cache like JRI mentioned? Usually it’s ctrl + f5 or something similar, but you can google “hard refresh [insert browser you use here]” to find out how to do it for you
BTW here’s a screenshot for ya of what I see:
Is this the previous or current version? Because if it’s the previous version then I would recommend checking your files and seeing if they were updated.
Also, a quick note for future reference:
Use the Hosting Support category for support requests. The informal category is for non-hosting related stuff, which isn’t what you’re looking for.
Ok thanks, I’ll go find the right forum, it still hasn’t solved the problem, thanks anyway.
