Maximum Users have already logged in FTP server Error
It’s known problem. I am waiting too :slight_smile:
This may be the general issue for the others also.
FTP down: 421 3900 users (the maximum) are already logged in, sorry
This is relevant to this topic
which is closed already and should be reopened again till it’s resolved ?
yea they should reopen it
epiz_25919939
I can’t upload files, because an error comes up “could not read socket”
Everything was fine until yesterday evening. It worked during the day, and I hoped it would today, but no.
I go into your Control Panel and the Online File Manager and it’s normally easy.
I need to access it, but if FTP is just down for a short time, just say so
Cheers, hope you can help.
yes same to me
We already did:
You need to wait to the oroblem will be fixed @anon19958674
I am trying from yesterday.
Hata: Sunucu ile bağlantı kurulamıyor
Durum: Yeniden deneniyor…
Durum: ftpupload.net için adres çözümleniyor
Durum: 185.27.134.11:21 bağlantısı kuruluyor…
Hata: İşlem 20 saniye içinde yapılamadığından bağlantı kesildi
I decided to research this and saw the pinned message and even though it says the issues have been fixed I still get them and I seem to be getting a completely unrelated error as well.
I just started getting this issue as of 1:30 PM GMT-5 time and the last time I tried connected was 8:40 GMT-5
Thank you to whoever responds to this!
@Admin is fixing the problem hold on!
ok thanks you
No problem ceck this out: Various system issues (DNS, SSL, FTP, etc.) starting May 15 - #82 by OverloadedTech
Well, possible good news… ftpupload.net port 21 seems to be offline. To eliminate possible local firewall issues, I checked with online port scanner, perhaps others can confirm.
First step to fixing is to perhaps take it all down for maintenance! … so, give it some more time I suppose.
we have to wait guys
Hey I was able to login into my FTP server this morning, maybe you guys might have some luck logging into yours!
Yep, this issue sounds like it is solved!
