Max. Post Size: Currently: 30 (the minimum required 32M)
https://carnomics.page.gd/. Not problem with site, it’s with Workpress.
This is the problem, I can’t active this Demo.
Please tell how can Upload the Demo?
The upload limit is globally the same for all accounts and cannot be increased on demand.
Is that warning really preventing you from importing the content? The Import Demo button doesn’t seem to be disabled. Many times, script just tell you that you’re not meeting the recommended settings, but will let you try anyway.
I tried it, sir. Then, everything I try to, it shows that. Like changing the flacon, shows error. See:
So, should I try manual installation?
See :sad_but_relieved_face:
The “critical error” just means that something crashed in WordPress. It could be that it’s caused by the POST size limit, but it could be something else.
Could you please try enabling WP_DEBUG mode and then try it again? That should give you an actual error message about the issue, which would help us identify the issue so we can try to solve it.
Notice: Function _load_textdomain_just_in_time was called incorrectly. Translation loading for the walcf7-datetimepicker domain was triggered too early. This is usually an indicator for some code in the plugin or theme running too early. Translations should be loaded at the init action or later. Please see Debugging in WordPress for more information. (This message was added in version 6.7.0.) in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/functions.php on line 6121
Notice: Function _load_textdomain_just_in_time was called incorrectly. Translation loading for the promotors domain was triggered too early. This is usually an indicator for some code in the plugin or theme running too early. Translations should be loaded at the init action or later. Please see Debugging in WordPress for more information. (This message was added in version 6.7.0.) in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/functions.php on line 6121
Deprecated: Creation of dynamic property CT_Redux_Extensions_ct_iconpicker::$field_name is deprecated in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/bravis-theme-core/inc/extensions/ct_iconpicker/extension_ct_iconpicker.php on line 19
Deprecated: Creation of dynamic property CT_Redux_Extensions_ct_auto_generate::$field_name is deprecated in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/bravis-theme-core/inc/extensions/ct_auto_generate/extension_ct_auto_generate.php on line 19
Deprecated: Creation of dynamic property Bravis_Theme_Core::$taxonomy_meta is deprecated in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/bravis-theme-core/bravis-theme-core.php on line 137
Fatal error: Uncaught TypeError: Redux_Filesystem::chmod(): Return value must be of type bool, null returned in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php:681 Stack trace: #0 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php(537): Redux_Filesystem->chmod(‘/home/vol8_4/in…’) #1 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php(383): Redux_Filesystem->put_contents(‘/home/vol8_4/in…’, ‘<?php\n class …’, ‘420’) #2 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php(302): Redux_Filesystem->do_action(‘put_contents’, ‘/home/vol8_4/in…’, Array) #3 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/extensions/customizer/class-redux-extension-customizer.php(245): Redux_Filesystem->execute(‘put_contents’, ‘/home/vol8_4/in…’, Array) #4 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(324): Redux_Extension_Customizer->create_field_classes(Array) #5 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(‘’, Array) #6 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/plugin.php(517): WP_Hook->do_action(Array) #7 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/extensions/customizer/class-redux-extension-customizer.php(611): do_action(‘redux/extension…’, Array) #8 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(324): Redux_Extension_Customizer->register_customizer_controls(Object(WP_Customize_Manager)) #9 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array) #10 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/plugin.php(517): WP_Hook->do_action(Array) #11 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-customize-manager.php(947): do_action(‘customize_regis…’, Object(WP_Customize_Manager)) #12 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(324): WP_Customize_Manager->wp_loaded(‘’) #13 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters(NULL, Array) #14 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-includes/plugin.php(517): WP_Hook->do_action(Array) #15 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-settings.php(749): do_action(‘wp_loaded’) #16 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-config.php(100): require_once(‘/home/vol8_4/in…’) #17 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-load.php(50): require_once(‘/home/vol8_4/in…’) #18 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-admin/admin.php(35): require_once(‘/home/vol8_4/in…’) #19 /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-admin/customize.php(13): require_once(‘/home/vol8_4/in…’) #20 {main} thrown in /home/vol8_4/infinityfree.com/if0_40434172/carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php on line 681
There has been a critical error on this website. Please check your site admin email inbox for instructions. If you continue to have problems, please try the support forums.
Learn more about troubleshooting WordPress.
This is the message I got.
This is extremely helpful! This tells us exactly where the error happens, and the function name gives some clues as to what it could be.
The function is called “chmod” which is related to file permissions. So based on that, it seems unlikely that the POST size is the issue.
Having a look at the specific code of that function, I think I see the issue.
Essentially, we have disabled the chmod function on our hosting. There is no legitimate reason to ever use it, it doesn’t fix any issues you may have, but can cause a lot of issues if used incorrectly. But I think that the specific way we disabled chmod, it is causing the redux-framework plugin code to crash.
I will submit a request upstream to get this fixed. In the mean time, you can manually edit the source code to work around this.
  1. Open the file manager.
  2. Go to the file carnomics.is-great.net/htdocs/wp-content/plugins/redux-framework/redux-core/inc/classes/class-redux-filesystem.php.
  3. Find the chmod function, which should start at line 666 (search for public function chmod).
  4. A few lines before that should be the line return $return;. Simply change that to return true;.
After that, you should be able to import your demo content without this error.
Okay, sir. I will edit it when I will get back home. Thank you & will let you know the results.
Just to let you know, the issue should now be fixed on our side as well. So if you haven’t made the code changes yet, please try importing the demo content again and see if it works now.
uh.. still showing error in Import Demo.
But, Settings are working :collision: I think it fixed!?
If you want to find out why, could you try again with WP_DEBUG enabled once more and share the error messages so we can see what’s going on? Maybe our fix didn’t solve the issue, or maybe there is another issue that also prevents the import from working.
But Importing Demo will reset the whole website & it’s file.. wait I think backup & restore theme settings.
