Yesterday, I was on the control panel and everything was fine. Today, I went into the Control Panel to find it says I’ve used past my limit of inodes, so I can’t use Softaculous or anything. I’m 99% sure I have not uploaded more than 30,019 files. Is there any way to fix this?
Now I can’t access the file manager, so I refreshed the page to find my account suspended for abuse.
My website is randomthings.cf.
The domain randomthings.cf is no longer attached to your hosting account, which is why it doesn’t display a website anymore. You should be able to add it again and restore your website.
Your inode counter also says you’re only using 15% right now.
@Admin said:
The domain randomthings.cf is no longer attached to your hosting account, which is why it doesn’t display a website anymore. You should be able to add it again and restore your website.Your inode counter also says you’re only using 15% right now.
Both the sub-domain (randomthings.epizy.com) and my domain redirect to suspendeddomain.org when entered. I was just uploading some files when suddenly it couldn’t connect.
