user12
June 23, 2025, 6:25pm
1
https://prism.free.nf/
Manifest: Line: 1, column: 1, Syntax error.
The problem is with manifest.json file when i visit network tab in inspect and select manifest.json in its header the content type is text/html but it should application/json
due to my manifest.json file show error
Welcome to the forum
I cant see the error your getting. is it only on a specific page?
But just a heads up, real time chat is prohibited on InfinityFree. You can embed chat’s hosted elsewhere, but you can’t have a real time or live chat hosted directly here.
Hello, and Welcome to the InfinityFree Forum!
Sounds like this is the reason for what you are seeing:
InfinityFree is a website hosting service. That means that the hosting accounts we provided are intended for hosting websites. Websites contain pages that are accessed through web browsers. InfinityFree is not intended to be used for file sharing, API hosting, database hosting or background tasks/tools.
To help enforce this, free hosting enforces a security system that makes sure that anyone trying to access your website is using a normal web browser. This is done by checking whether the web br…
user12
June 24, 2025, 6:09am
4
See here is the problem content type is text/html it should application/json
Did you read what @Jri-Creator posted? That’s why it is happening.
user12
June 24, 2025, 6:36am
8
why it is down login and register page work good and other page work if directly type url it open.
Admin
June 24, 2025, 9:42am
9
I don’t know why it doesn’t work, but I can tell you what you should do: you must delete the software from your website.
Your account was suspended because you hosted a chat script. So you must remove the chat script.
system
Closed
July 1, 2025, 9:43am
10
