I am having problem’s logging into my account as the login details are no longer working - i think after changing the email address: (if0_35001633!) https://dash.infinityfree.com/users/6842712/
I was last able to access in early September.
The SSL Certificate for my site has expired and I now can’t update the Cert credentials.
Can someone possibly reset the credentials for me?
If you forgot the password, you can request a password reset using your email address. If you’re having problems logging in after changing your email address, please try logging in with both the old email address and the new one, in case the email change hasn’t gone through completely yet.
I don’t know what else you expect me to do. But if you think that I’m going to send you the login details of a client area profile if you give me a username, then think again. While I am technically able to reset passwords, I also have the responsibility to keep our users’ data safe, and simply resetting and handing out login details is not the way to do so.
Is it possible to remove the custom domain from the account that I no longer have a working email address for (if0_35001633!) and to start a new account?
