epiz_28860831 185.27.134.55
The admin panel and the site load for a very long time (4 min) or with an error
Sometimes Error 502
Ray ID: 6b0422058c72ffc8 • 2021-11-18 21:01:14 UTC
Sometimes Error 502
Clear your cache
If you want u can test it https://pixels.ml/ but its not cache problem
Your site took about 22 seconds to load this homepage:
I see you use WordPress, so it is most likely a local cache issue.
Also, https://pixels.ml/wp-admin/
took 44 seconds to load.
You may want to inspect your plugins and themes.
Can you share your SQL Cluster? It is found in the Client Area.
