Links Preview for Meta tags
(nengoz.xyz)
(My site is not previewing meta tags and description when I enter the url on social apps like Whatsapp, Facebook, the link is not previewing meta data)
Welcome to the forum!
But I am using a custom domain not a free domain and I have some other sites that I created in May 2023, the meta tags worked perfectly without any issues
I believe you used Cloudflare with your custom domain during that time?
It is true that sites using Cloudflare were exempt from that security system, but due to a recent change, Cloudflare is also no longer exempt from it. To learn more why it happened, please read this thread:
Specifically:
Yaa , it’s true that time I used cloudflare and everything worked smoothly, so do you mean for now there is no way to show meta tags previews even if I have a custom domain not a free subdomain , Is there a way out or?
Yes, unfortunately, there is no way to disable that system in free hosting anymore, even if you have a custom domain and use Cloudflare. This means Opengraph meta tags will not work in most places.
:sob::sob::sob:so it means we are now stuck ,so it’s now bad for us , so what we will do then ? It’s painful for me
Well you can’t do anything if you wanna host here. Or better upgrade to premium. At last its your choice.
Hi. It did not work for me in free plan and without changing anything it works now (see nice site).
Can I see the link
