Key / CSR generation not working.
Hi.
I was trying to generate Key / CSR on cPanel, but when I generate it, it won’t show up.
What’s the reason of that? P.S. I filled everything correctly.
I’m not sure why this issue happens, but it seems you’re not the only one with the problem: https://forum.infinityfree.com/discussion/2517/csr-not-generated-on-clicking-generate-key-csr
However, for that account I could not reproduce the problem, so you may also want to try again to see if it works now (just be sure to fill in all form fields in the CSR generation page).
