cURL SSL Error with Jetpack:
When connecting Jetpack plugin, I get the following transport error:
IXR -32300: transport error: http_request_failed cURL error 56: OpenSSL SSL_read: OpenSSL/3.5.7: error:0A000126:SSL routines::unexpected eof while reading, errno 0 (Status 500)
It seems outbound cURL requests or SSL handshake with WordPress.com servers are being blocked by the server firewall or SSL settings.
Social Preview Failure:
Social platforms and oEmbed generators fail to scrape metadata/OpenGraph tags from my site, giving errors that preview cannot be generated.
Could you please check if outbound cURL requests are restricted, and ensure SSL/TLS settings and firewall rules allow external crawlers and WordPress.com connection?
Both problems look like the same thing, and it isn’t an outbound cURL or SSL restriction. All free accounts have a browser security system that only lets through visitors who can run JavaScript and accept cookies. It can’t be turned off on free hosting.
The Jetpack error says the Jetpack server couldn’t communicate with your site, so the failing request is WordPress.com connecting in to you. Outbound requests from your site to other services work normally. The article below lists WordPress XML-RPC, cURL-style tools, automated bots and webhooks as things this system blocks. Jetpack’s connection goes through XML-RPC, so I think that’s what’s failing, though the article doesn’t name Jetpack. Social preview scrapers and oEmbed fetchers are automated clients without JavaScript or cookies, so they would hit the same wall. The article lists 403 Forbidden as the usual result, which fits the “Permission Denied / Connection Blocked” errors you’re seeing.
Editing .htaccess or robots.txt won’t change this. The article says the check can’t be disabled on free hosting. Its suggested alternative is premium hosting, which uses less restrictive protection that lets APIs and automated tools through.
Here’s the article describing what the system blocks and what still works:
A similar crawler complaint is here, though I found no answer in it:
I couldn’t find a documented way to get Jetpack connected on a free account, so I can’t say there’s a workaround.
Basically what the bot said. Automated access and crawlers are blocked for the most part (only most search engine crawlers are exempt) on free hosting. This is intentional, and so this cannot be “fixed”.
I don’t know the Jetpack extension that well so I cannot tell you what it does, whether the security features on free hosting prevent it from working entirely, and what functionality is available through it or can be delivered through other extensions instead.
Outbound cURL requests are allowed for the most part (a few specific services are restricted, which does not include wordpress.com), but inbound requests (which is what Jetpack is running into) is restricted.
