Issued SSL certificate is not being served
https://weightlosssupplementblog.com
My domain weightlosssupplementblog.com still serves the default self-signed certificate on both the main domain and www.
The free Let’s Encrypt certificate is issued, and the dashboard reported installation successful. I also re-saved it through the control panel, but Verify Installation still says Not Found. DNS points to the hosting account’s assigned IP, and the issued certificate covers both hostnames. Could staff check why the issued certificate is not being served?
The article on installing SSL certificates says it usually takes a few minutes for a certificate to take effect, but it can take longer than an hour. Until then, Live SSL Status and Verify Installation show “Not Found”, and browsers can show a self-signed certificate. It also says that installing the certificate again may help.
When did the certificate finish installing? If it was within the last hour or so, this may just be that delay.
Which IP address do weightlosssupplementblog.com and www resolve to right now? Your hosting account’s website IP is 185.27.134.106, so I’d like to know if that’s what your DNS returns.
Here’s the article:
No issue
