Issue
https://tensionrelease.rf.gd
Howdy!
WordPress has a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with one of your plugins, BuddyPress.
First, visit your website and check for any visible issues. Next, visit the page where the error was caught and check for any visible issues.
Please contact your host for assistance with investigating this issue further.
If your site appears broken and you can’t access your dashboard normally, WordPress now has a special “recovery mode”. This lets you safely login to your dashboard and investigate further.
https://tensionrelease.rf.gd/wp-login.php?action=enter_recovery_mode&rm_token=ZuaOmuOSELG0ifXGnxovgk&rm_key=4CZhf1Hxmh1ITw6RBge5uP
To keep your site safe, this link will expire in 1 day. Don’t worry about that, though: a new link will be emailed to you if the error occurs again after it expires.
When seeking help with this issue, you may be asked for some of the following information:
WordPress version 6.8.1
Active theme: BuddyX (version 4.8.3)
Current plugin: BuddyPress (version 14.3.4)
PHP version 8.3.19
Please help me
This may be more applicable to you
I do not see any issue
What should I do now? How can I solve this? Please give me a solution.
You are accessing this website using HTTPS, but your WordPress Address and Site Address are not set up to use HTTPS by default.
Talk to your web host about supporting HTTPS for your website.
Learn more about why you should use HTTPS(opens in a new tab)
Change your site URL in Wordpress settings to be https instead of http. Not sure why all these messages say contact your host, there are not things we can fix.
I think the error messages are aimed at services where wordpress comes preinstalled, and you don’t have the same level of access to the admin side… but thats just a guess
We could fix them, but it just takes a lot of effort.
That’s also why these plugins have these messages. They are basically saying: “We detected an issue with your website, but working with you to fix this website takes a lot of manual work that we don’t feel like doing. But you must have a hosting provider right, so just bother them instead of us, OK?”
They probably already built a free plugin or theme, and are not getting anything in return, so they don’t want to spend their time helping you build your website.
But we’re providing free hosting, you’re not paying us either, so there is just as little incentive for us to help you with this either.
We’re happy to point you in the right direction, but we’re not going to fix your website configuration just because a plugin you installed says that we should do that for you.
Except that all these messages are generated by WordPress core. A plugin might have an error, but eventually it’s WordPress itself sending out the email. (And it’s generic.)
