Issue with Routes in React Application Hosted on InfinityFree
Dear InfinityFree Support Team,
I am experiencing an issue with the routes of my React application hosted on your service. Below is a detailed description of the situation:
Problem Description:
My application is developed with React on the frontend and uses PHP to access a database. The entire project is hosted in the htdocs folder on your server. The application works correctly in my local environment, but when I deploy it on InfinityFree, I can only access index.html. The routes configured in React do not work properly when I try to access them directly via the URL.
Example of the Problem:
  1. When I navigate to https://darrona-pedidos.free.nf/lista-de-precios, I get a 404 error that says: “The page you were looking for could not be found!”
  2. However, if I navigate through the application using internal links, the routes work correctly.
Current Configuration:
I have tried configuring an .htaccess file in the root of htdocs with the following rules to handle the routes of the React application:
<IfModule mod_rewrite.c>
  RewriteEngine On
  RewriteBase /
  RewriteRule ^ index.html [L]
</IfModule>
I also tried the following alternative configuration:
Options -MultiViews
RewriteEngine On
RewriteBase /
RewriteRule . /index.html [L]
Despite this, I keep receiving 404 errors when I try to access the routes directly via the URL.
Request for Assistance:
I would appreciate your help in resolving this issue. Could you provide guidance on how to correctly configure the routes for a React application on your platform? Is there any specific configuration I need to adjust in the .htaccess file or on the server to make the routes work properly?
Additional Information:
  • Domain: https://darrona-pedidos.free.nf/
  • Location of .htaccess file: root of htdocs
  • Type of application: React frontend with PHP backend
Thank you in advance for your help. I look forward to your response to resolve this issue as soon as possible.
Sincerely,
Natalia
It has something to do with how you have React handling requests.
If I make a HTTP request the URL, it fails with a 404 error (As you said), but when I use the internal linking, I don’t actually make a HTTP request to that page, everything seems to be handled via JS. My best guess is that you don’t have a way for HTTP requests to be handled, only the internal navigation structure is correct (Even if I reload the working page, an HTTP request to that URL is created, causing it to fail).
I am not honestly sure how you would investigate/fix this (I don’t use React), but maybe you can use it as a starting point.
Thank you for the response. I just realized that my .htaccess file was incorrectly written - I was able to fix it, thanks!
