Issue with FTP over TLS Connection
Website URL:
https://hangman-game.ct.ws
Error Message:
Status: Initializing TLS...
Status: Waiting to retry...
Status: Connecting to ...
Status: Connection established, waiting for welcome message...
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 378 of 6900 allowed.
Response: 220-Local time is now 28:30. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220 You will be disconnected after 60 seconds of inactivity.
Command: AUTH TLS
Response: 234 AUTH TLS OK.
Other Information:
I’ve been using Filezila to manage my website files via FTP over TLS without issues until recently. I now experience a connection timeout while trying to establish a secure connection (TLS handshake). I’ve confirmed that plain FTP works, but I prefer using FTP over TLS for security purposes.
I’ve tried troubleshooting by reinstalling FileZila, checking firewall/antivirus settings, and using different FTP settings, but the issue persists. Could you please confirm if there have been any recent server-side changes or provide any troubleshooting steps for resolving this issue?
Thank you for your assistance!
Hey there!
It seems like you’re having trouble with the TLS handshake when connecting via FTP over TLS, while plain FTP is still working fine. Here are a few things you can check:
  1. Server-Side Changes: It’s possible that the server made some changes recently. For example, SSL/TLS certificates could have expired or the server may have disabled support for older TLS versions (1.0/1.1). I recommend checking with your hosting provider to confirm if there have been any updates on their end.
  2. FTP Settings in FileZilla: Double-check your settings in FileZilla. Make sure you’re using the right encryption setting—either “Require explicit FTP over TLS” or “Use explicit FTP over TLS if available.” Also, try switching to Passive Mode if it’s not already selected (this can sometimes help with TLS connections).
  3. Firewall/Antivirus: Sometimes, local firewalls or antivirus software might block the connection, even if plain FTP works. You might want to temporarily disable your firewall/antivirus to test if that’s the issue.
  4. Server Logs: If you have access to your server logs, look for any errors related to TLS/FTP. That might give you more insight into what’s failing during the handshake process.
  5. Test with Other Clients: To rule out any issues with FileZilla specifically, try connecting with another FTP client like WinSCP or Cyberduck. If they also fail to connect via FTPS, it’s likely a server-side issue.
  6. TLS Version: Some servers no longer support older versions of TLS for security reasons. If you’re able to, try adjusting the TLS settings in FileZilla under Edit > Settings > FTP to match the server’s supported TLS versions (e.g., TLS 1.2).
  7. wait until Infinityfree responds
Hope that helps!
Given that the connection times out after enabling TLS, my first guess is that a router or firewall may be blocking encrypted FTP connections. Some routers or firewalls insist on injecting themselves into the connection, and that’s not possible when the connection is encrypted.
Using a different network connection (or possibly a VPN) could help. If your virus scanner has a firewall, maybe try disabling that too.
Could you please verify the things that an AI feeds you next time before posting? That way, you don’t post suggestions that are clearly not possible, refer to options that don’t exist, or you can confirm yourself too.
Hi Admin,
Sorry for my reply.
After watchimg all the opics in the forum
I came to this topic, So I wanted to tell something and I made this wrong decision to answer from AI. I won’t do that again. My bad
Thankss, switching to a different network worked for me! but I don’t get it, why is the network causing this issue out of nowhere… it used to work just fine.
Could be your isp either blocking something or getting a false positive on their virus protection.
Happens far to often
