Issue with Connecting Database to My PHP Application
Hi everyone,
I’m facing a bit of a challenge with my PHP application hosted on InfinityFree, and I hope someone here can help me out. I’m trying to connect my PHP script to a MySQL database, but I keep getting an error message that says, “Unable to connect to the database.”
Here’s a bit more detail on what I’ve done so far:
  • I created a MySQL database through the InfinityFree control panel.
  • I double-checked the database name, username, password, and hostname in my PHP code to ensure they match the ones provided in the control panel.
  • I’m using mysqli_connect() to establish the connection.
Despite all this, I still can’t seem to connect. Is there something I’m missing? Could this be related to some server settings or permissions that I haven’t configured correctly?
I’d appreciate any insights or suggestions you all might have. Thanks in advance!
If that does not help share your code and hide your password.
I figured out the issue, and it was a small mistake on my part.:sweat_smile:
It turns out that in my PHP code, I mistakenly typed the database hostname as localhost instead of the actual hostname provided by InfinityFree. Once I corrected the hostname to match the one in my control panel, the connection worked perfectly!
Thank you.
