Issue with 'allow_url_fopen'
Hello,
I’m encountering an issue with my website where the software I’m using reports that the allow_url_fopen directive is not enabled, even though I understand this setting should be enabled by default on InfinityFree.
Details:
  • PHP Version: 8.2.21
  • Website URL: teramod.site
  • Document Root: /home/vol10_2/infinityfree.com/if0_37093998/htdocs
The software I’m trying to install requires allow_url_fopen to be enabled, but the installation process fails, stating that it is not enabled. I’ve checked as much as I can on my end and believe this might be a misdetection, but I’m not sure how to resolve it.
Could you please help me verify if this setting is indeed enabled or suggest any solutions to fix this issue?
Thank you for your assistance!
Hi and welcome to the forum!
Please don’t use AI to write your posts, as it can be a bit misleading and overcomplicates the context we need a bit more. Prolonged use of AI will get your future posts flagged and deleted.
Also, I checked on a test file I created and the function is on, so I guess it could be a problem on the detection script your software uses, which thinks that allow_url_fopen is disabled while it’s actually enabled (because, when it’s actually enabled, our servers use on instead of what it’s expected on the detection method they’re using to check whenever it’s enabled, like On as an example). You might need to talk to the developer about that.
Thank you for the reply
how do i get in touch with the developers ? I already know this directive is enabled but its not detecting as its enables, i need help with this, it is enabled i already know that, but why its not letting me install a website second i want to know how to i install additions softwares into the cpanal software section ?
Thank you again
is this the same zontal ? this might be something else :rofl:
where did you download zontal ?
