Issue installing wordpress
Hi
I recently signed up for infinity free hosting for a website im wanting to create.
I have a domain name which is: homedecorworld.club
When i go to install the wordpress App it goes through the motions as if its installed the app and gives me 2 addresses:
http://homedecorworld.club
And an admin one
http://homedecorworld.club/dir/wp-admin
Both the addresses go to a page im guessing is a temporary default page waiting to be edited but niether of them have anywhere to login to the admin part to do this.
I can not see where wordpress has installed when i look in file manager either.
Iv tried removing it and reinstalling it but get the same outcome.
Is there something wrong with wordpress not installing which is preventing me from been able to login to the admin site?
Regards
Philip
Can you try to remove and re-add the domain from the “Addon Domains” section on the Control Panel? That should push the changes in the network, and will take at least 72 hours before accessing the website again.
I’ll give that a try cheers
Your domain doesn’t seem to be working at all from my end. The nameservers are currently pointing to ns1.theworldofmensfashion.club and ns2.theworldofmensfashion.club, which don’t appear to work. If you change that to ns1.epizy.com and ns2.epizy.com, that should work.
