One more thing about this: if while trying to recover password from wordpress(to see if it was due to any problem with password), if I didn´t consent to receive emails when creating hosting, could this affect to wordpress being not able to send? If so, are there ways to fix it, from infinityfree or from wordpress?
I’d be happy to check it for you, but then I do need to know which website you’re referring to. Can you share the URL?
As for the email issues, PHP mail is effectively disabled on our hosting, which is likely the reason that the emails are not working. If you want to send email from your website, you can configure an external SMTP service for that instead (there are a number of WordPress plugins for that).
However, since you have access to the underlying hosting, there are a number of other approaches you could try to reset your WordPress admin password: Reset your password – Documentation – WordPress.org
Thanks for your answer. I think I have fixed it.
