epiz_30300368
There’s an error when i try to install woocommerce plugin on my website, is this anything related to hosting or not? Can anyone please help asap.
ERROR:
Installation failed: 502 Bad Gateway 502 Bad Gateway nginx
epiz_30300368
ERROR:
Woocommerce is generally a large plugin to install, it exceeds the maximum upload limit in free hosting. You could upload the files manually however I would recommend looking for an alternative plugin. Woocommerce uses up too much server resources and can easily get your free hosting account suspended.
I used this plugin 100 more times before and worked perfectlly. Also I tried manually installation but didn’t worked either.
No it does not. I used to use it.
That is true
Is that the only error message given? How old it the account?
almost 1 year i think
