Installed Let’s Encrypt certificate is not served for cerenhediyelik.com.tr
https://cerenhediyelik.com.tr/
The browser reports net::ERR_CERT_AUTHORITY_INVALID. The InfinityFree SSL/TLS page shows Live SSL Status: Not Found, while Installed SSL Status says the Let’s Encrypt certificate is installed.
The custom domain is attached to the same website directory as cerenhediyelik.gt.tc, where the storefront loads. Public DNS returns the InfinityFree hosting IP 185.27.134.252. The Let’s Encrypt certificate was issued and automatically installed from the dashboard. Could you check whether the custom domain is mapped correctly on the live HTTPS server and why it is not serving the installed certificate?
How long ago did you install the certificate? If it was less than a few hours ago, it may simply not have taken effect yet.
The SSL install guide says a new certificate usually takes a few minutes to take effect, but it can take more than an hour. Until then, Live SSL Status and Verify Installation show “Not Found”, and browsers can show a self-signed certificate or NET::ERR_CERT_AUTHORITY_INVALID. That matches what you’re seeing. The guide also says it may help to install the certificate again.
Here’s the guide:
If it’s been well over an hour and a reinstall doesn’t change anything, tell me roughly how long it’s been and whether you tried reinstalling. Also check the domain in an SSL checker, or in a private browser window, because Chrome can remember an old certificate for a few hours.
