Installation failed: Could not create directory
https://vonrottweilerpuppies.com/
(Installation failed: Could not create directory. /vonrottweilerpuppies.com/htdocs/wp-content/upgrade/under-construction-page.3.97)
(This happens each time i try to install a plugin on the site)
Hi
Can you create any file or dir?
I ask that because you may have reached the inode limit
and check CHMOD for this dir (never go below 600)
https://vonrottweilerpuppies.com/wp-content/upgrade/
