It’s because iFastNet is down. Let me know if it creates an issue. Anyways, because iFastNet is down with zlib, it’s not able to recognize it. Hopefully it gets resolved soon.
I heavily recommend you reinstalling everything you’ve installed manually during the outage just to make sure.
Not yet. Try installing a plugin. If it says anything about zlib, then it’s not fixed. If the installation through Wordpress was successful, then yes, and I need an eye exam, think I’m goin blind on issues.
If you’re talking about updating the WP version, you can do so by downloading the latest WP fr,om wordpress.org and then use an FTP client to upload it to your website folder. I don’t know much. I’m just trying to help but that’s how I updated mine. You would probably have content as well so don’t know how will it work with that.
lot hassle , don’t get me wrong this issue should have been sorted out as soon as possible , fear enough we are using their hosting for free but once again i still think we shouldn’t go through all of this . Thanks .
Forum mod BayoDino said there were not as many issues back then. Again, it is free hosting, not meant to be great. Hopefully this issue does get resolved soon.
