My question is: Why in input radio ,like : input type=“radio” id=“javascript” name=“fav_language” ,
taked from W3Schools, in test script, I see two signs ?.. ? around the circle - for choosing one option. How to avoid this undesireble signs.
my first assumption is that you have some character that is not utf-8
so the browser doesn’t know how to display it but give us the code so we can check
NOTE - it should definitely have at least two choices so that it can be unchecked if clicked again
and make sure that ID doesn’t repeat.
or use input type="checkbox" if there is one choice
Some times someone may be late to reply, some times you may not get a response at all. In this case it’s only been 9 hours; be a bit more patient
Clarification
In case this isn’t clear, my response is going to katesmith1304’s response above, not to the OP. Additionally I am referring to an OP replying; you’ll always get a reply from a forum user or the Admin when opening a new topic, but do keep in mind those may come a bit late as well
