This discussion was created from comments split from: HTTP ERROR 500.
hi,
can u tell me my cpanel shows inodes used as half done in green, so if it gones to full green will my account be barred or suspended or will it expire. can us plz elaborate my issue.
@Manish88 said:
hi,
Inodes are the number of files and directories in your account. The only way to lower the usage is by deleting files from your website. If you hit the limit, you will not be able to create new files and directories, which could cause your site to break down. Your account will not be suspended.
what is the disk space given at the time of hosting…
The disk space itself is unlimited, that’s kind of our biggest selling point.
my website is takimg to much time to load earlier it was quick can u suggest any measures so that my site becomes faster
I split the topic, since this topic has nothing to do with the website error of @GoldTec
A few tips:
- Check how well your site is optimized on http://gtmetrix.com . The provide useful tips on how to make the page faster.
- Make sure your script runs as fast as possible. Get a fast theme, disable slow plugins or plugins you don’t need and setup caching.
anything i can change in web hosting to make website faster because i have received the HTTP 500 error aftert this error was sorted out website became slow. earlier it was fast
