InfinityFree SSL not working
All Custom domains that I made (p4rty.host, p4rtyhost.com)
SSL certificate error: The provider encountered an error verifying the DNS settings of your domain name. Please verify your DNS settings and try again later.
Error detail: DNS problem: looking up TXT for _acme-challenge.p4rty.host: DNSSEC: DNSKEY Missing: validation failure <_acme-challenge.p4rty.host. TXT IN>: No DNSKEY record [misc failure] from 198.251.90.216 for key p4rty.host. while building chain of trust
Using default InfinityFree SSL providers don’t work. Even after switching providers it still does the same thing I have set up the records and checked them and it said I did
You have DNSSEC on which is not supported
thanks
I see you are making a small file host. Please know that whatever people upload is your responsibility and that if anyone uploads something against the rules your account will get suspended
I have a built in automod
Automatic upload filtering is good, but let me tell you from extensive experience that reliably detecting anything bad through upload filtering isn’t going to work. You do need human review on top of that, and a good reporting system.
