InfinityFree Control Panel Not Found Error
https://glowarticle.42web.io
Hello InfinityFree Support,
My hosting account is Active, and my website glowarticle.42web.io and WordPress Dashboard are working. However, when I click Control Panel, I get this error:
Not Found — The requested URL /panel/modules/signout/index.php was not found on this server.
I have tried Incognito Mode and a different internet connection, but the issue still persists. Please help me fix this problem.The requested URL /panel/modules/signout/index.php was not found on this server.
Thank you.
Usually, that error means that your account is in the process of being deactivated. Normally, that should only be a temporary state and the suspension should make itself apparent within a few minutes, but there is an ongoing issue affecting account status changes, so that’s why it didn’t appear.
I manually synced your account status so it correctly says Processing now. But you’ll need to wait fr that issue to be resolved to see why it was suspended and how you can get it back.
