Infinite loading on the index of my site
I don’t know why, since yesterday the first page of my site (hard-questions.com) has not been loaded but all the others are being loaded, for example: hard-questions.com/articoli-pc
To me it loads fine, consider to clear your cache.
(Remember, you must speak in English)
What browser are you using?
I cleared the cache but it doesn’t work the same. are you sure it works? try to update because i tried in another device and it didn’t work. Will it be a server question? I am in Italy
what error do you receive?
There is no error, it simply does not load
I don’t really know what to do
can you press F12 to see if there are any messages?
also gives me error 522 so I can’t inspect anything :sob:
when the servers work i will let you know … i hope as soon as possible
