http://vnp.free.nf/
It automatically redirects to site https://errors.infinityfree.net/errors/404/
Hi everybody,
my main page is on index.php. It is in folder /htdocs where I made a new .htaccess file too with content: DirectoryIndex index.php but it doesnt work, the page is not accessable when I try load. What can be the problem?
You don’t need the DirectoryIndex in your .htaccess
As long as your index.php is in the /htdocs folder you’ll be fine.
That was the first problem, that I had that index.php file in /htdocs and it doesnt work that way. That is why I tried the htaccess file…
this is the content of the htdocs folder
That should be working fine. what error are you getting without the .htaccess file?
Remember to clear your cache to make sure thats not causing problems.
I tried incognito mode on chrome and it redirects me to this site: https://errors.infinityfree.net/errors/404/
I’m thinking the problem may be with your index.php then.
Are you calling any other scripts in there that might be causing the problem?
You were right, I hade some absolute paths in the index.php from localhost server… I corrected them on the webserver, now it works. I tought that if that would be a problem, the site would show other errors… thanks a lot for your help.
Easy mistake to make
glad its working for you now
