address
FTP authentification failed
Hello
73 hours ago, I created a new site because of the troubles with 000.pe
I try to upload all files with Fzilla in vain.
I tried with filemanager on your web site, in vain. What’s wrong ?
I’ve got screen copies of my filezilla screen. I can’t see where to post them. Sorry.
your site is up and working
you should find a directory in your root named photornithorandosmerand.lovestoblog.com and inside that you should find another directory called htdocs and it is here you need to upload your website (and delete the index2.html if you wish)
the ftp logs that KangJL requested will help determine whats going wrong
Hello, I enebled debug menu in FZ but it still doesn’t work : I get this :
Suivi :
CFtpLogonOpData::Send() in state 6
Commande :
USER if0_38011201
Suivi :
CFtpControlSocket::OnReceive()
Suivi :
tls_layer_impl::on_read()
Suivi :
Réponse :
331 User if0_38011201 OK. Password required
Suivi :
CFtpLogonOpData::ParseResponse() in state 6
Suivi :
CControlSocket::SendNextCommand()
Suivi :
Commande :
PASS ************
Suivi :
Suivi :
Réponse :
530 Login authentication failed
Suivi :
Suivi :
CRealControlSocket::DoClose(1094)
Suivi :
CControlSocket::DoClose(1094)
Suivi :
CFtpControlSocket::ResetOperation(1094)
Suivi :
CControlSocket::ResetOperation(1094)
Suivi :
CFtpLogonOpData::Reset(1094) in state 6
Erreur :
Erreur critique : Impossible d’établir une connexion au serveur
When I try to use file manager from infinitysite I get an error message about FTP
Thanks for helping !
Hello, I answered Kang and posted thge error message from Filezilla Suivi : CFtpLogonOpData::Send() in state 6
Commande : USER if0_38011201
Suivi : CFtpControlSocket::OnReceive()
Suivi : tls_layer_impl::on_read()
Réponse : 331 User if0_38011201 OK. Password required
Suivi : CFtpLogonOpData::ParseResponse() in state 6
Suivi : CControlSocket::SendNextCommand()
Commande : PASS ************
Réponse : 530 Login authentication failed
Suivi : CRealControlSocket::DoClose(1094)
Suivi : CControlSocket::DoClose(1094)
Suivi : CFtpControlSocket::ResetOperation(1094)
Suivi : CControlSocket::ResetOperation(1094)
Suivi : CFtpLogonOpData::Reset(1094) in state 6
Erreur : Erreur critique : Impossible d’établir une connexion au serveur
Did you make sure to log in to the Control Panel first to enable FTP access, as said by this article?
Being able to access your hosting account over FTP is very important to manage your website files. However, there are reason why you may have trouble connecting to the FTP service. This article explains a few things you can try to fix your FTP connection.
Login to your control panel
After your account has been created, or reactivated after a suspension, you may need to login to the hosting control panel once to enable FTP access to your account.
You can login to the control panel by logging in…
I think I’m doing all that I must do but one thing is surely missing ! Which one ? (PS I’ve been using FZ for years !) I tried to post screen copies of FZ control pannel but it looks I’m not allowed to !
Thank you
You have to go to Client Area and then visit your hosting account control panel, not filezilla’s control panel
OK, the error came from FTP hostname which was written "ftpupload.net " somewhere and not infinityfree.
I works now, than you very much
