Just looking at the way you are doing this, I think it will immediately start returning incorrect album covers as soon as more than one person is using the website at the same time.
xhr ajax looks you done already.
I remember now to get toDataUrl working need to add onload ev on method i told before.
my function in /js/fetch_updater.js in the debugger is loaded and run bbut does not provide base 64 information I dont know why
function CheckResponse(transport) { var content = transport.responseText; $time = new Date().getTime(); new Ajax.Request("outer_img2", { method: "get",onSuccess:function s() { this.document.getElementById("outer_img").innerHTML = "<img id=#np_track_artwork src=/images/nowplaying_artwork_2.png?t="+$time+" alt='Playing track artwork' width=200 height=200>"} }); } }
= New Ajax.request
Need to checked it out later. Works or not.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=9" />
<meta name="viewport" content="width=device-width, initial-scale=1">
<script type="text/javascript" src="src/js/jquery-3.4.1.min.js"></script>
</head>
<body>
<img id="img_artwork" width="220" height="277"
src="http://viena.lovestoblog.com/imgEdit/img/edwin.jpg" alt="Lesson">
<script>
function process() {
alert("start");
//var image = document.createElement("img");
//image.src = 'http://viena.lovestoblog.com/imgEdit/img/nowplaying_artwork_2.png';
//var base64file1;
//image.remove();
data=document.getElementById("export").value;
alert(data);
var base64file2 = data;
$("#img_artwork").attr("src", base64file2);
alert("ok");
</script>
<h1>HTML DOM Events</h1>
<h2>The onclick Event</h2>
<p>The onclick event triggers a function when an element is clicked on.</p>
<p>Click to trigger a function that will output "Hello World":</p>
<button onclick="myFunction()">Click me</button>
<button onclick="p1()">img Click me</button><br>
<button onclick="process()">Process</button>
<input onkeypress="process()" type="text" id="export" name="export">
<p id="demo"></p>
<script>
function myFunction() {
document.getElementById("demo").innerHTML = "Hello World";
function p1() {
alert("00");
const toDataURL = url => fetch(url)
.then(response => response.blob())
.then(blob => new Promise((resolve, reject) => {
const reader = new FileReader()
reader.onloadend = () => resolve(reader.result)
reader.onerror = reject
reader.readAsDataURL(blob)
alert("11");
toDataURL('http://viena.lovestoblog.com/imgEdit/img/nowplaying_artwork_2.png')
.then(dataUrl => {
console.log('RESULT:', dataUrl)
document.getElementById("export").value = dataUrl;
alert("ok");
function px() {
alert("00");
alert("ok");
</script>
</body>
</html>
no. Its the reverse. So take a look of your timer decay. As you requested its all working before.
Where is your decay function i donât see it anymore.
OK, yes, the background update of the image isnât affected by this.
Iâm not exactly sure how browser cache and AJAX work together.
I would test it, but the fetch_updater.js because of a Uncaught SyntaxError: illegal character U+2018 on fetch_updater.js:103:31. That line renders as var startDate = new Date(ââŹË1/1/2019ââŹâ˘); // this, which doesnât seem OK.
I browser cache with AJAX works the same as without, then adding any query parameter to the fetch URL should solve it. The elapsed time code you have right now should do the trick, but it seems like youâve tried a lot of different things so Iâm not sure if the code is being hit properly.
Also, having file names per track would really help with this too, then you can just use Javascript to update the image src attribute and the browser will load in the new image. Might be a bit easier than downloading it through Ajax.
Uncaught SyntaxError: illegal character U+2018onfetch_updater.js:103:31. That line renders asvar startDate = new Date(ââŹË1/1/2019ââŹâ˘); // this, which doesnât seem OK.
Fabulous detective work Admin i wish it had better syntax editor in the editor. I will et you know what happens to update have just removed single quotes replacing with double. I hope it solves this .
The weird thing my cloud is still showing old code how do i clear this in debuger please to get a fresh look ?
Hugs D
I donât think its getting the base64 still Admin
Letâs keep the discussion in this topic since thatâs where most of the posts are in:
Username (e.g. epiz_XXX) or Website URL epiz_33087480 (please specify the website or account you are asking about) http://www.deniserose.epizy.com/fetch_sql.php Error Message (please share the FULL error message you see) This page isnât working www.deniserose.epizy.com is currently unable to handle this request. HTTP ERROR 500 Other Information None of my php pages seem to be running any ideas please ? Thank you for looking as these run on my previous site elsewhere. D
