You should see all the images that are in that directory right now
See the image. theres tons of images but i’m not sure why they’re not being displayed:/
Is there a timmyweather.rf.gd/htdocs directory in your hosting account?
yes it is
Go to timmyweather.rf.gd/icons . What did you see?
I guess you will have to wait for admin
icons seems to be a reserved folder name; use another name for your folder and update your links, and your images should work.
You can verify this by taking a look at my test website’s icons folder which is identical to yours: https://do.epizy.com/icons/
I tried creating another folder and adding one image and it did work. I didn’t know icons is reserved for this… it’s weird because today morning and before lunch it did work, but after lunch it did not…
Good catch!
I’m not sure if this is intended behavior, but this is how it currently works - having a look at an old topic, it seems to be related to the directory listing functionality:
According to that same topic the ability to override it used to be there, or if not override then add custom icons, maybe @lovebug who had a look into it back then could help us:
As an interesting sidenote, https://do.epizy.com/iconsx/ gives a 403 Access Denied message.
thanks again for both of you:) never knew icons is reserved. is there any name that is reserved for a specific task?
I believe the only reserved words are icons, iconsx, and includes (this one is not web accessible). The former two are reserved symbolic links to the Apache icons.
To include chat, chats
