I want to delete my Site Pro build and use WordPress instead
angelikalenz.great-site.net
I tried out the Site Pro builder but don’t want to use it and will install WordPress instead. From previous posts in the forum I gathered that I should delete the index.php file in htdocs, I did that. Is that all I need to do? Just double checking because I want to start clean and avoid having any issues from this in the future.
If you want to start very clean then you may as well delete other files created by Site.Pro. They’re also not useful for a WordPress site.
Hey, thanks. There don’t seem to be any other files created by Site.Pro as far as I can gather from the file modification dates. So I’m good?
Then yes you are good to go.
Just noticed it still says ‘Website created‘ on my dash for this domain, is that an issue?
If you never touch the Website Builder button again then you’ll be fine.
Okay great, thank you!
