I really need it uploading its a library for like thje main settings of my website i would really appreciate it if anyone could upload it for me or tell me how to make it smaller tysm ![]()
You can split it into multiple files and use
require_once()
bro i have no clue how to do that can you do it?
You can split different parts of your PHP code and then use include[_once] or require[_once]:
<?php
include "splitfile.php";
include "splitfile2.php";
Or
require "splitfile.php";
require "splitfile2.php";
The main difference between include and require is that require will stop executing when it encounters an error by throwing a fatal error while include doesn’t.
Lastly, the difference between the _once version is that if you already included or required that file before, it won’t include it again which will prevent some errors.
include "config.php";
include_once "config.php"; // This won't do anything
https://www.php.net/manual/en/function.require-once.php
https://www.php.net/manual/en/function.include-once.php
i made the file into 982kb but it still wont upload, why???
What’s the error?
You probably need to compress it more, since it is around 1MiB so anything under 950KB should be fine.
