PM me?
Yes can you crat it to me please i can’t do it still anavailable
Please do not give your job to someone else unless they want to pay for them.
Best regards.
Freenom is very glitchy, not working properly on other parts of the world these days.
I guess dot.ml is also?
But it is not working i need help
Change your location by using VPN!
I did everything that u told me about still i can tegister
Not working also cause if you use to find .ml domain on dot.ml then it will redirect you to freenom for registration.
It’s what i meant.
private message me then I’ll help you out, its free
but only this time (leave this for me, moderators, Thanks!)
Can you check if your IP is listed as blacklisted to internet anti spam databases?
Check here: https://whatismyipaddress.com/blacklist-check
I also had this problem and i found my ip is listed as blacklisted to one of the internet anti spam databases.
Hello, yes you can, just go to Cloudflare and install it!!!
Install what
You have to put your website (no sub domains), sellect a plan that you want (free is a great way to get started), replace the name servers (it won’t affect your hosting), go to SSL and put flexible and always use HTTPS
3 posts were split to a new topic: Illegal characters in source hostname part. 10
