hello, is this domain pointing to infinityfree servers? and I installed a free SSL on it but the website is not working : amw-construction.com.eg
For me your website points to our servers, works fine, shows the default page and has a valid SSL certificate installed to it, so now you’re ready to upload your website. If it still doesn’t work for you, can you try clearing your browser cache or use incognito mode to bypass any cache?
If even with the browser cache cleared your website doesn’t work on your side, you might need to wait for DNS propagation or try the workarounds in this article:
thanks, its now working but the website URL is red " your connection to this site is not secure"
Now you’ll also have to force SSL on your website as well since it didn’t redirect to HTTPS on your side:
i will install wordpress, should i select http or https to install on ?
Since you have an SSL certificate, you can now select HTTPS to install it on; just ignore the warning message that will pop up that will say that a trusted SSL certificate was not found as, since your website is working with HTTPS, your website will still work with that protocol, and keep installing it as normal after that.
thanks for help my friend, i will do it, I appreciate your time
