I need a sql backup
https://pokemonultimateleague.freehosting.dev
Hello. I need to export/download a backup of my MySQL database because phpMyAdmin is currently inaccessible and returns ERR_CONNECTION_TIMED_OUT.
Hosting account: if0_42341239
Database: if0_42341239_pokemonultimateleague
Could you provide a database backup/download link?
Welcome to the forum
This is a community forum so none of us here have access to do that (wit ha possible exception of admin)
That said, I’ve checked and I can access PHP my admin suggesting its not a hosting side issue. can you try accessing on a different network or using a VPN to see if it’s a network block thats causing the issue
Oh im so sorry Im a little noob here. My page has an alert on top that says:
Domain howto.rocks not resolving
Affected: Free Subdomains · 1 other incident
And also a Status Page:
9 August 2026 at 21:22 UTC
▲ Disrupted
This issue is not resolved yet
Investigating - Our registrar has confirmed that they still have not received a response from the registry regarding this matter. (21 Aug - 08:03 UTC)
Investigating - The domain name appears to be suspended by the .rocks registry. We have reached out to our domain registrar to learn more about this. This may be related to the nfy.fyi suspension, as both extensions are maintained by the same registry (Identity Digital). We are trying to see if there is any connection between them. (10 Aug - 07:28 UTC)
Investigating - We are investigating an issue affecting the availability of the domain howto.rocks. Websites hosted on subdomains of this domain may be unreachable. (9 Aug - 21:22 UTC)
It seems there is a problem with the page itself since 9 august and I dont know how to solve it. I will try to get a VPN also, thank you for response.
That notice is a general error for all domains under the howto.rocks domain.
The same issue is impacting the nfy.fyi domain.
Since your domain is under the freehosting.dev domain this error doesn’t affect your site.
You can ignore this banner. It only impactcts people using those 2 domains.;
