I have a question about SSL
custom-keto-diet.infinityfreeapp.com
Hello,
I am trying to add SSL to the above website, but my website still comes up as “not secure”
I clicked on Free SSL Certificates, New Certificates. I set up the CName record manually.
I copied and pasted the Private key and the Certificate, and uploaded them.
I received a green notice that said: SSL certificate installed.
But when I enter the above URL into the box, I get a notice that the URL is not secure.
Is there a way that I can fix this?
Thank you.
Try doing this:
Thank you for the reply Frank.
Is there something that I need to do to enable SSL?
Thank you.
SSL is already enabled for your site, since you have already installed the cert.
The only thing you need to do is to force all traffic to HTTPS. Please follow the guide I gave you.
Hello Frank,
I am somewhat of a newbie. I have read the articles, but I have not been able to force traffic to https://. How do I open the Wordpress dashboard on my Infinityfree.com website. so that I can add the really-simple-ssl plugin to my website.
Thank you.
You did not read the guide carefully. This is what you should be doing
Adding to what me and KangJL said, you should also update your WordPress site url. Go to your wp-admin and go to Settings. Then you are good to follow the guide.
