I deleted and reupleaded index.html and now it redirects me there. How to fix it?
what is your website url ? so i can check it
Hello.
Note that it is “index.html” not “Index.html”. InfinityFree servers are case-sensitive.
http://nbn-d.42web.io/
It works now, thanks a lot
rename Index.html to index.html and all should be fine
— edit —
greenreader beat me to it :grinning:
There is also a way to treat a file that has a name other than “index” as the main one. You would have to look it up though, I don’t know it off of the top of my head.
Correct. You can set index pages with htaccess.
https://tinkertechlab.com/webhosting/htaccess/setting-index-pages
