If I click on Control panel for Softacluse Installation
My cPanel can’t open because it’s continuously loading.
Try to reloading the cPanel again please
it’s can’t work continuously Loading
Screenshot please?
That was posted several days ago, of which a fix has been aquired.
A fix was applied, but it doesn’t appear to have properly solved the issue.
A few errors were identified in our integration code, which have been fixed, but it seems that the new ad network we’re integrating fundamentally clashes with the control panel code, which may cause it to crash randomly (depending on timing?).
I’m going to dig into this more, but it seems like it’s complicated to fix.
In the mean time, clicking the logo to force a page reload is the only workaround I can offer.
